Hi everyone,
I want to ask a question that how can I recover deleted videos from IPhone 5S. I had a lot of videos in it but due to my mistake I deleted the folder itself. So please tell me is there a chance to get back those videos or any app that may help me to recover deleted videos. Please let me know if there is any solution to it.
de Blair
10 points
How to recover deleted videos from Iphone 5S?
It happens to lot of people. But this is not that big problem until you have not synced your phone with iTunes. If not, then all of your data can be easily recover using some recovery software.
The easiest and simplest workaround is to trying recovering directly from your iTunes account. Follow these steps:
Connect iPhone to your computer using data cable.
Open iTunes. iTunes will either prompt automatically to restore from backup. If not, go to “Devices”, at the left side menu<< tap cntrl+click “iPhone”.
Select option “Restore from Backup”.
Select backup file and click the “Restore” button. Your data will sync back to your iPhone.
If this process fails to help you, then you need some power full data recovery tool to perform this task. Here I will show you an example of applying such tool and recovering back videos for your iPhone.
The tool we will discuss here is “PhoneRescue” developed by “iMobile” this is one of the highly recommended data recovery tools used for iPhone data recoveries. Download this tool from its official website to avoid any type of security threats for your computer. This is available in both, MAC and Windows version. There are basically two ways of data recovery, which this tool provides:
Recovering directly from the iPhone:Steps for recovering data using PhoneRescue tool are as follows:
Install and launch the tool in your computer and then connect your iPhone using data cable.
When tool identifies your phone, select option “Recover from an iOS Device”.
In the next window, select the type of data you want to recover, here, you will select “Video”.
Click button “Start Scan”. The tool will now scan your device for deleted videos.
Now you can see preview of thumbnails of deleted videos. Select your desired videos.
When the attempt of recovering deleted iPhone videos is not successful from 1st method, there is another way to recover and extract videos using iTunes backup files with PhoneRescue tool.
Recovery using iTunes Backup files: Steps for recovering data using PhoneRescue tool:
Just like steps mentioned in first workaround, connect your iPhone to our computer, after launching this tool.
Now select “Recover from iTunes Backup Files” this time instead.
PhoneRescue will now scan computer and enlist all stored iTunes backup files.
Select your phone’s “iTunes backup”. Now extract it.
Now choose video files to recover by selecting file type option.
Click “Start Scan” button to scan this iTunes backup file for videos.
When you get the list of thumbnails of video files, choose your files, you wish to restore.
Now press “Restore” button to perform the operation. This will save your videos to you computer.
Once you succeed to restore your files, you can transfer them back by using iTunes to you handset any time.
Hope this information will help you to recover back your lost data..
