Hello friends,
How to recover disk space roxio? I just uninstall my roxio dvd burning application in windows 7 operating system but after the installation process I just noticed that the mb file size occupied by the application before was not added back in the disk as consider as free space. What should I do?
Thanks and Regards,
Jessica Allen.
You have to free up the disk space which was taken by Roxio.
That can be done by deleting old saved states.
Just follow these directions and you'll restore your disk space:
1) Select Instant Restore -> Free Disk Space -> Disk cleanup.
2) Select BackOn Track Saved States.
Doing the two simple steps should free your disk space.
Dear Friend,
When you uninstalled the program you have not removed its roots in the disk so you must use a program for cleaning the registry of your machine.
For cleaning your registry I recommend C cleaner it is a good program and free software, once you have downloaded it start to clean your registry. You will find the program on the following link.
http://www.piriform.com/ccleaner
