How to recover fifa 12 crash at main menu ?
Hi Experts,
I am having ms excel 2007 and I am having a excel file called fifa 12.When I try to open it,it had crashed.I need to know how to recover fifa 12 crash at main menu.Please advice me on this.Thanks.
Calistamadisonn
Answered By 590495 points N/A #141696
Normally, in Microsoft Office Excel, there is no problem opening documents or worksheets created on older version of the program from Microsoft Office 97 until Microsoft Office 2003. I think this is what you called backward compatible. If by any chance your Excel file crashed when you tried opening it on the 2007 version of Microsoft Office Excel, the file probably is already corrupted.
To try and fix this, open again your Microsoft Office Excel 2007 and then click on the Office Button found at the left-most corner of the application then select Open. After this, browse and select your fifa 12 Excel file and then select Open and Repair from Open’s drop-down menu and then just follow the succeeding on-screen instructions that will be displayed on your screen.
Open’s drop-down menu.
The Office Button.
