zahidali
Posted on - 09/23/2011
I have lost my Gmail account password, unfortunately I can't remember my security question & primary email as well. I tried to recover it but I can't. I believe that some one should have an answer, so please help me to recover it.
mikekay
How to recover a Gmail account without password & security question
Ohh! no zahidali,
Its really so sad that you forgot all about your Gmail account. You have written that you don't remember your 'primary account', I guess you meant secondary email account.
In case you can't remember your password, username, security question and even your secondary email address, then there is only one solution for you zahidali. You will have to contact Google support Centre (https://support.google.com/mail/?hl=en) and present to them as much details about your account as you can in odder for them to verify that your the true owner the account.
Good luck.
Your Gmail account has a password reset tool that allows you to reset the password by way of challenged questions, cell phone, and alternate email address. Once you forget the security question and alternate email, then you can still reset the password by using cell phone numbers.
In this way of resetting the password, an SMS notification from Gmail will give you the code and this code needs to be inputted in the space provided in password Gmail tool. Once the code has been accepted a computer-generated password will be provided. Change all challenged questions, and update alternate email address for future reference. You might encounter the same issue sooner or later.
