How to recover iso files for images?
Hello! I have tried to recover data from my WinXP hard drive using R-Studio. Unfortunately, none of my .iso files were recovered. Other than these .iso files, everything was recovered. Does any of you here know how to recover iso files using R-Studio? Please help me with this problem. Thanks in advance!
Best Answer by Mullins Debord
Answered By 0 points N/A #179126
Hello Elin,
I know how painful and frustrating it is for your hard drive to get ruined like this.
Of course you'd be keeping that hard drive in a safe place until you get the solution for recovering it's contents. Now, you could try Remo Software, boasting of recovering .iso file types. Else, this is another option, Isobuster.
Answered By 0 points N/A #179127
Hi Elin Ortie,
I have here one good application that is free of use and is user friendly, the application is called Daemon Tools. It has the capability to Extract and look what's inside the .ISO's files and then you may do several tasks like copying and pasting method from the .ISO disk image file.
Answered By 5 points N/A #179129
Erasure of data from the computer deletes every bit of that data from the system. R-Studio is only helpful if and only if you lost your files due to corruption caused by viruses. Corruption destroys the data partially and hence make it possible to analyze and  recover it. Though, there is a software that can help you solve your problem. Recuva data recovery software is the ideal software to recover data from your hard drive.
