Hi techyv,
How to recover lost phonebook blackberry? I just deleted all the contacts accidentally last night while browsing my contact lists, I am worried and don’t have any idea to recover those files in my phonebook. Those contacts are very important for me, if there is a way to solve this problem please let me know.
Hoping for your help. Thanks.
From your description I come to know that you want torecover lost phonebook from blackberry. I can help you step by step.
Please follow the instruction
· Connect your Blackberry to the computer on which you have the BlackBerry Desktop Manager installed. Launch the Desktop Manager software.
· Select "Backup and Restore," then click on "Restore."
· Locate the backup file with your contact data. This file will be in the default location unless you have previously changed it. For Windows XP this is C:Documents and Settings<username>My Documents and for Windows Vista it is C:Users<username>Documents
· Double-click on the file, which will have a (.ipd) file extension. Synchronize your Blackberry device with the Desktop Manager, which will restore your contacts.
Hope your problem will be solved soon.
