How to recover missing library Solitaire Master 2
Hi everyone, hoping that someone can help me with a missing library Solitaire Master 2 as the software is not running properly. I don't have an installation disk and am at a loss as to what to do next. Thanks in advance!
Answered By 0 points N/A #91007
Hello there, if the program is not running properly. You can do the following:
1. Upgrade your antivirus software and scan your computer for viruses. Viruses can cause these kind of things.
2. Uninstall any recent program you installed.
3. Check the minimum system requirements to run Solitaire Master 2. If your system isn't compatible with the application, it won't run.
4. Restore your system back to a time when it was still working okay.
5. The other thing you can do is to uninstall and re-install the program. You'll need the installation file. You don't have the disk but you should be able to download it online.
