How to recover missing, lost, or deleted files
Before checking the recommendations and suggestions next, verifying that really the files have been eliminated; in some cases the files can move. The hard disk drive for the files that you believe to be missing executing find to look or to look in the team(equipment).
To recover the safety copy file
If the file has been a copy on diskette or another way recommends to itself to restore the file of the safety copy if the file is not.
Restoration of the stationer or Stationer of recycling
If XP is executing MacOS de Apple, Microsoft Windows 95, NT, 98, 2000, ME, Sight or later operating system and the file has been eliminated recently it is possible that the file can still be in the garbage or Wastebasket(Stationer) of recycling. If it is present inside this area it can be recovered.
To recover an eliminated file of the wastebasket(stationer) of recycling of Windows.
To unload free software or a buy program
Below there is a list of free software of programs of recovery of files that it is possible to use freely to recover lost information.
In addition to previous freeware you program there are also several companies that have created programs designed to recover the lost information. For example, PowerQuest does that the utility of the image of unit(unity) that, in some cases, can be used to recover information of a hard disk.
To use a service of a company that specializes in the recovery of lost information
To use the service of a company of local data recovery or a company of data recovery of the state(condition). A precaution word is that these services sometimes can be very costly. It is recommended only to use if the information is very important. Below there is a list of some important companies of data recovery.
Also there exist several companies that specialize in the service of recovery of files or documents that are protected by password. Next it is a list of some of the companies that offer this service.
Hello Jhjuisaha,
To recover your missing, lost or deleted files you can use a software called 'RecoverMyFiles' which you can download its trial version for free online. Just go to the following url and download Recovermyfiles:
http://www.recovermyfiles.com/
Once you have finished downloading it, install it on your computer, and then run/execute it.
Locate the drive that had the files before they went missing, or were deleted and choose the option to recover the files on that drive. Wait for the process to finish; it will take some time because it will recover all the files that have ever been deleted from that drive.
When it finishes the recovery process, choose the files that you will like to save and choose a destination folder to save them which should be the same place as the drive.
__
Regards
Lee Hung
Side by side, other softwares are also present described in this Techyv page that does good job.
