Bryan James
30 points
Posted on - 11/19/2012
Hi to everyone,
How to recover overwritten psd Mac?
What is the most recommend solution regarding this matter?
I need some advice on how to recover those psd files that I have overwritten under the Mac operating system.
I thought the psd was separated by another file.
I need some help.
Hi!
Just a tip: after your pictures have been accidentally deleted, do not put anything on your hard disk. Stop using it for the moment to avoid physical damage.
Photoshop PSD Repair helps you scan storage media to recover not only PSD but also PDD files during a data loss situation.
There is also Data Recovery for Mac, which works the same way, only it's cheaper than the first one.
You can download the free version of Stellar Phoenix Mac Data Recovery 5 on your Mac.
Install and select your drive for recovery.
You can also navigate to advance setting feature which lets you scan only particular files (like psd in your case). Please avoid any further use of the drive as the deleted file information may get overwrite and unrecoverable.
Find more info: https://www.stellarinfo.com/mac-data-recovery.htm
