How to recover sbs 2003 pop3 connector?
Hello fellows,
How to recover sbs 2003 pop3 connector? I don’t know the step by step process to get this done as fast as I can because I have something more work to do. I just want to ask you guys if you know some techniques or ideas regarding this matter. I hope you can help me.
Thank you.
Best Answer by marsh watson
Answered By 60 points N/A #180181
Hi Anthony Wendy,
I think that the posts/comments in the link of site below would help you with your problem.
Whirlpool SBS 2003 Recover POP 3
That has small comments but I think it is very helpful with your problem. It has a lot of information that you need.
Hope it would help you.
Answered By 0 points N/A #180182
To do the required task you have to follow these simple steps;
·         Navigate to this path program filesmicrosoft windows business servernetworkPOP3.
·         Register all the .dll here.
·         Run IMBREG.exe
·         Now, restart the POP3 connector for SMTP and mailbox service.
·         Finally, run the command prompt and execute “iisreset”
  Hopefully this will fix the problem.
