After smooth running while taking of 12 images by using the new memory card I have bought,
I got the message that it can't be initialized.
I have taken a trial to run it by using SDHC reader on my PC, but it failed to access.
I think that after formatting it will be ok, but I really wish to recover SDHC Card files, firstly my images.
Have any suggestion please?
How to recover sdhc card files?
Hey Dudley Achan,
Good News for you. Now you can recover your lost memory card data preferably in its original condition.
All you need is a tool called DataRecWizPro stable version is 4.3.6.
You can easily download this software online.
You should be able to recover the data after connecting your memory card through a card reader to your computer.
Try not to format the memory card (low level) when your card is corrupted or gives you error while initializing because in this case the electronically saved data sectors are erased individually from all the sectors available on the memory card.
If you have quick formatted your memory card then you are in a luck.
Thanks
SDHD or the Secure Digital High Capacity cards are often easily damaged or get corrupted. If you are having troubles on accessing it, try the following workarounds below:
1. Ensure that the memory chip inside the SDHD is not damaged. Look for any fissure on the chip itself as this is the reason for lost data.
2. Purchase recovery software such as MemoryCardRestore, Recover Plus Photo Recovery and Undeleter: Safe File Recovery. Install it and run it on your computer.
3. Bring your card to any recovery expert such as Recoverfab. They offer reasonable fees.
