Hi Experts,
I am having windows vista on my pc. My colleague has deleted my software shred files. I want to recover software shred deleted files. I tried to recover it from the recycle bin but it was unsuccessful. Help me to achieve this.
Sharlene Ruby
How to recover software shred deleted files?
Hello Sharlene.
Shred Deleted Files is a software that guarantees all your deleted files are permanently gone in your computer system. Sad to say, you cannot recover your files anymore. But there is no harm done if you will try to recover it by using applications that can retrieve deleted files. But there is no guarantee that you can restore files that are deleted thru Shred Deleted File.
Hello Sharlene,
You can use a 3rd application called Smart Undeleter to recover your deleted files if you cannot be able to retrieve the files from the recycle bin. With this application, you can be able to recover the following files:
Files that have been emptied from the Recycle Bin, or those bypassing it.
Files which could have been deleted by viruses or application programs.
Files which were accidentally deleted on a shared network.
Files that could have been erased using removed directories.
Any files that were removed prior to your Smart Undeleter installation.
Or the files that were deleted using a DOS prompt command.
Smart Undeleter is a powerful data recovery software utility which you can use effectively to recover deleted files.
Carl
