How to recover text messages from phone?
Hello Experts,
How to recover text messages from phone? I deleted some important text messages a few minutes ago by mistake and I want to recover those text message files. How will I be able to do that? Is there a way that we can get them back from my phone? I hope you can help me.
Thank you.
Best Answer by Nelson David
Answered By 0 points N/A #178950
Connect your phone to your computer through a USB cable or insert the phone's SD card into the SD card-reader slot in your computer.
Search freeware data-recovery programs online like Recover, File Recovery 4 and Smart Recovery 4.5 and then download the program and save the file. Open the file recovery program.
From the file recovery program menu, select your phone's internal storage drive or memory card.  You will see a list of deleted text message files from your phone.
Select the text message that you want to recover by clicking it. Click the "Restore" button and it will be then restored to your phone.
You can now disconnect your phone’s SD card from your computer or disconnect the USB cable.
Answered By 0 points N/A #178951
Dear Chloe Chylly,
Follow these instructions:
  1. Purchase and install SIMC on. Put in the SIM card into a reader and run SIMC on to recuperate newly deleted messages and export them.
  2. Purchase and install Sim Card Data Recovery. It tries to recover any and all deleted data.
  3. Purchase the Cell Phone Spy. This tool works with the built-in software to reassign all data from a SIM card for control and viewing, including newly deleted text messages.
Answered By 0 points N/A #178952
Buy and install SIMCon, insert your Sim card and install the SIMCon. After the installation, the setup will recover the recently deleted messages. Once the text messages are recovered, they will be exported to the SIM card.
Alternatively, you can install Sim Card Data Recovery software, which has the ability to recover any deleted data and contact details.
