How to recover Windows XP Admin Passwords?
Hi All,
I forgot my Windows XP Admin Password and I want to ask how I can recover it again without using any means of illegal software. Can someone please provide answers? Thanks.
Thank you.
Hi All,
Thank you.
Glad that you are looking for a legal way to resolve your issue. Intruders and breaking into someone else's computer is strictly prohibited in this website. This website is to help people learn how to use computer perfectly. If you forget the password of your computer, try re installing the computer's operating system and that will solve the problem.
Thank You.
Happy this you are interested q=looking for in a new authorized method to solve your own problem. Criminals q=intruders and also busting in to somebody else's pc is actually purely banned on this web site. This site q=learn how to is always to guide persons be able to usage pc
correctly. In case you your investment pass word of this pc, test re also setting
up this pc's operating-system and this may resolve the trouble.
Hello
I am providing you a solution on a basis that you are using it for your own personal computer or Laptop.
Windows XP and later versions have got an inbuilt method to recover lost or forgotten passwords. You can do this through ‘Password Reset Disk’. Just go to Control panel and click on User Accounts. Now you see ‘Prevent a forgotten password’ link. Follow the instructions given thereafter and you are done.
Thanks
Kemper Luke
You don’t need to undergo any complicated procedure to reset your Windows XP password, which is good news for those who are not technologically savvy. What you need is a password reset software program that automatically resets the password for you when you run it on your computer. Most of the time, the basic process of using a password reset software program is something like this:
1. You download the software program online from another computer (ask a friend or neighbour if you don’t own one).
2. Once you have downloaded it, burn it onto a disk. You can also use this disk in case you ever lose your password again. Some developers also offer the option of putting the software in a USB stick instead.
3. Switch on your computer and run the disk. The software program should launch and reset the password for you.
Regards
