Whenever I try to print something from Adobe Acrobat reader I face an error while printing. Is there anyone, who know the cause and would help me to rectify acrobat cannot print security issue? Any kind of help would be appreciated.
How to rectify acrobat cannot print security issue?
There are a few possible solutions for your problem.
1. Check that you have selected the correct printer in the print dialog box.
2. Check to see whether print to file box is selected. If it is selected, then deselect it and try.
3. Download Adobe Reader 9.5 from here — http://get.adobe.com/reader/enterprise/.
4. Try to print files for other software like Word. If it does not get printed then uninstall and reinstall the printer software.
5. If you can print files from other software like Word, then convert your PDF files into word so that you can print them. You can get the software here – https://www.pdftoword.com
Hope this information helps you.
If you have a problem with Adobe Acrobat Reader, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select Adobe Acrobat Reader among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install Adobe Acrobat back. If this doesn’t help, try downloading the latest. Go to the Adobe Acrobat Reader DC download page. Here, select your correct operating system from the dropdown. Next, select the language. And then last, select the available version from the dropdown based on your selection.
Configure your download by checking or unchecking other options under “Optional offer” then click to download Acrobat Reader. Alternatively, try installing Foxit Reader if you still have a problem with Acrobat Reader.
