How to redirect email received in yahoo mailbox to outlook inbox
Hi Dears,
Is there any way that I can redirect the emails from my Yahoo mails inbox to Microsoft outlook inbox?
Thanks in advance.
Hi Dears,
Thanks in advance.
Hey dear,Â
hope you are all well. yes you can redirect the emails from your yahoo mails to outlook inbox.
You have to follow the following steps.
For Outlook 2007
 1. First Setup the YPOPS https://www.techspot.com/downloads/1725-ypops.html
 2. Then click on Outlook Menu,  select on Tools —> Account Settings.
 3. Select E-mail tab , Click New . Ensure Microsoft Exchange, POP3,IMAP and HTTP is selected. Then click Next.
 4. Write your name in Your name: .
 5. Type your yahoo email. at E-mail Address.
 6. Ensure Manually configure server settings or additional server typers is checked.
 7. Click Next.
 9. Ensure POP3 is selected in Account Type: .
10. Type " 127.0.0.1" in both Incoming mail server: and Outgoing mail server(SMTP): .
11. Write your Yahoo ID in User Name: . (if  yahoo email is" [email protected] " then the ID will be "Senroat.")
12. Write your yahoo mail password under Password: .
13. Click More Settings
14. Go to the Outgoing Server tab. Ensure My outgoing server(SMTP) requires authentication is checked.
15. Leave Use same settings as my incoming mail server selected.
16. Click OK.
17. Click Next.
18. Click Finish.
For Outlook 2003
 2. Then click on Outlook Menu,  select on Tools > E-Mail Account.
 3. Ensure Add a new email account is selected.
 4. Click Next. Check POP3
 5. Click Next.Â
 6. Write your name in Your name: .
 7. Type your yahoo email. at E-mail Address.
 8. Type " localhost" in both Incoming mail server: and Outgoing mail server(SMTP): . IF it does not work try "127.0.0.1"
    instead of "localhost".
 9. Write your Yahoo ID in User Name: . (if  yahoo email is" [email protected] " then the ID will be "Senroat.")
10. Write your yahoo mail password under Password: .
11. Click More Settings
12. Go to the Outgoing Server tab. Ensure My outgoing server(SMTP) requires authentication is checked.
13. Leave Use same settings as my incoming mail server selected.
14. Click OK.
15. Click Next.
16. Click Finish.
 That's, all you need to  do.
Dear A K Azad,
When you will first open your Microsoft Outlook, it will give you a pop up box.
First write your name, in the second message box it will ask for your mail address.
There you have to write your yahoo ID, and the rest, click just next button.
It will automatically configure your setting.
This is the easy way.Â
I hope this will help you.
Thank you.
