Carle
10 points
Posted on - 07/20/2011
I installed software such as Yahoo Messenger or OnlyWire submitter. I want to be directed to the site when clicking the Mozilla or Google Chrome button.
Currently, the default official site of Yahoo Messenger is in IE browser. How do I make arrangements to be directed to the Mozilla Firefox or Google Chrome, because I think   IE is very slow in  loading.
sarilla
How to redirect to mozilla firefox on Yahoo Messenger
Dear Carle.
The solution of your problem is very simple for making Yahoo messenger as a starter page on Mozilla Firewall or Google chrome. You can simply go to your Mozilla Firewall or Google Chrome browser's settings and make yahoo as a start page.
The procedure making the setting is:
<Go to the Tools <Â Options < General settings < Write yahoo messenger on home page tab.
Hope this solution will help you.
Janine08
5 points
Hi this are some of Instructions, I hope it will help.
1 Hold down the "Windows" button on your keyboard, and press "R."
2 Type "computerdefaults" and click "OK."
3 Click "Custom," and select "Choose a default web browser."
4 Select "Mozilla Firefox," then click "OK."
Chevene
To change Google Chrome to your default browser follow these steps:Â
1) Open Google Chrome and click on the small wrench icon in the upper right corner of the screen. When the drop down tab/menu appears you then select the choice named options.
2) The options dialog box should now be open, click on the basics tab. At the bottom of the dialog box there should be a section marked: Default browser. Click the button marked: Make Google Chrome my default browser. Conformation text should soon follow validating the change.
Carle
10 points
I finally get to choose which browser when clicking on links fromYahoo Messager.. Thanks a lot all!
