360mall
110 points
Posted on - 04/22/2011
Hello everybody!
In my Laptop I am having two operating systems so whenever i switch on my laptop or re-start, it will wait for around 30 Sec and ask me to choose one from those O/S.
My question is; Is there any way to reduce this timing (30Sec) or i want to remove this option and directly load my XP O/S when i switch on my laptop.
Please help me.
onezero
How to reduce the 30sec. wait time while dual booting OS?
Ok we can do this within a couple of easy steps
Right click on “My Computer” which is on your Desktop
Click on “Properties”
Click on “Advanced” tab
Under Startup & Recovery Section Click “Settings”
Under System startup section, select which Operating system you need as Default
And remove the check mark of “Time to display list of operating systems”
Click on “OK”
You are done!
360mall
110 points
Oh Thanks for your clear instruction.
I appreciate it my friend.
onezero
You are welcome.
And if you have any doubts just post your questions in Techyv any of our members can help you with pleasure ok.
360mall
110 points
Yes sure.
I thing this is a good place to share our knowledge and ask our doubts.
Because we can get instance answer from site experts.
360mall
110 points
Actually I am having another doubt that, I want to get a clear idea about that also.
But I am not sure whether,
I can ask the question here in the same thread or I should make a new post?
onezero
If your doubt is related to this question, No harm about asking your doubt in this thread but if the subject is different, Then you better ask this question in a new post as this would help others to identify the subject and question easily if they have any doubts related to that subject.
So then they can just search by any of the key words which related to their question without asking the question from the beginning and waiting for an answer.
Hope you understand this.
