How to reduce lags in strike gamepad nfs run?
I have recently played strike gamepad nfs run. But I've been experiencing lags and pixilated graphics. How can I reduce these problems in strike gamepad nfs run?
Hello Hink,
This problems seems to be a hardware issue. Your game might not be getting the minimum hardware resources required to run because of the resources might be engaged with another application running in the background. It is also possible that your pc doesn't fulfill the minimum requirements to run the game.
Check the hardware specifications of the game and compare it with your PC configuration.
If your PC resource seems to be low from the minimum hardware requirement, try to upgrade your PC to fix the issue.
