How to refresh pivot table without having trouble on reference?
Whenever I try updating the Pivot Table using the Refresh Data key, I kept on receiving the error message saying “Reference is not valid”. Is there anything I can do to refresh the data?
I hope you can help me. Thank you.
Answered By 75 points N/A #105204
Hallo Willie,
Is the refreshing key you are using F5? I will advice that you unplug the keyboard and plug it in again, maybe it has just frozen.
Otherwise try closing the application that you are using for updating the pivot table and then launch it again. Ensure that when pressing the refresh key on the keyboard which should be F5 you are not holding down other keys at the same time, because you may be using a key combination that does no have really exist.
I hope this helps you fix your problem.
__
Regards
Lee Hung
