Ayswaria
Posted on - 01/11/2013
When I try to open my laptops webcam, it shows the message there is no hardware, software and reinstall with disk but I can't get any disk with my laptop. Where will I get software ?
How can i lost hardware from the laptop?
How to reinstall LG laptops webcam?
Hi Ayswaria,
    This problem generally occurs when your system got crashed or your system files get corrupted then this type of problem generally pops up. But there would be no problem, as every problem has its solution, and this problem also gets solved when you reinstall your webcam driver.
   Yet, it would be difficult for you to locate the driver for your webcam as it would be different for every brand, as HP has its own hardware configuration and Acer has its own. Just you have to visit that website of which company you have the laptop then you might find out the driver that would be suitable for your webcam.
Thanks
