The Infrared driver on my Toshiba laptop was deleted accidentally. How can I reinstall it back on my Windows 7 laptop? What are the things to consider before reinstalling this Infrared driver?
How to reinstall my infrared driver Toshiba Windows 7 in my laptop?
Go to start menu from the taskbar of your computer Â
click the all programs and find the Accessories folder then choose System tools and then select System Restore
then click the Restore my computer to an earlier time and then click next at the bottom. Then choose a date in the calendar shown the Restore point page, choose the date an earlier before the day of deletion occurred and then click next, Then the restoration will start and your computer will be restart and just click ok after the completion window appears after you computer loads again.
Hello Rosie,
As you deleted the install version of infrared driver, it is better to install again the driver from your backup file. Besides, you have to face problem. If you have no backup file, you can download it. You can download any drivers for Toshiba from https://support.toshiba.com/  here.
You can also solve your any kind of troubleshooting problem of Toshiba computer. They support all time in online Toshiba client.
Hope, it will help you.
Regards
Taylor
