Hi. I have recently started using Norton 360 and because I was facing some problems with it, I removed it. Now, I wish to install it again. How to reinstall Norton 360? Please reply ASAP. Thanks in advance.
How To Reinstall Norton 360 In Simple Steps
To learn how to reinstall Norton 360, first download the Norton remove and reinstall tool and the file needs to be saved on the desktop. However, the file automatically gets saved on a few browsers. Then, open the download window on the browser and double-click on the NRnR icon. Then, agree to the terms and conditions which have been mentioned in the agreement. Next, select the remove and reinstall option, continue and select the restart now option to install the Norton 360 again.
After the install completes, the instructions which appear on the screen need to be followed.
Hope we helped.
