E.Robe
10 points
Posted on - 09/02/2016
Hi. I am not very thorough with the concept of Windows installer. I want to install the Windows installer again but don’t know how to go about doing it. How to reinstall Windows installer? Please reply ASAP. Thanks in advance.
B.makone
10 points
How To Reinstall Windows Installer Using Some Simple Steps
Hi. To learn how to reinstall Windows installer, click on start and in the search box type notepad and open it. Then, click on the notepad file from programs. Click on file, and then save the file with the reg extension. In the save as type, select the option of all files and then select the file on the desktop by clicking on save. To close the notepad, select Exit from the file menu. Right-click on the file which has been saved on the desktop and then run as an administrator.
Type the password twice to confirm the password and then continue. Install the registry keys by clicking on yes. The installation process should be started again for the program which has to be installed.
Hope we helped.
