How to remotely shut down home PC?
Hi experts,
Hi experts,
Hi Mr. Robin,
Hello Dear,
Thanks for sharing your problem with us.
Dear there are many software are available in market which can makes your this task done.
I suggest you to use "Team Viewer" in this regard.
It is a best remote control software. You have to just set it up in your computer as i am going to tell you.
Download it from this link.
Install it. When you will connect to the internet after installing it. It will show you "Your ID" and "Password" you have to remember your computer's that id. You can set a specific password to your computer. To set a password click on "Connection" and then choose "Set Unattended access" then it will require password twice which you want to set.
Now whenever you want to control your computer, simply open team viewer and type computer's ID in partner ID box and type that password that you have set already on that.
It will connect you with that computer without any authorization.
You can control it.
Thanks
