How to remove 360 safeguard?
Hello experts,
I would like to delete or uninstall my 360 safeguard in my computer for some reasons.
Can you give me a step by step process on how to remove it from my Windows XP operating system?
Thank you.
Best Answer by Michelle Karla
Answered By 0 points N/A #179242
Hello Madison,
To remove safeguard from your computer, you will just need to use the add/remove option from the control panel. Also, removing the registry key might allow you to get rid of but first off you will need to follow the instructions in the link below and make sure that you delete any files or folders that you can find: HKEY_LOCAL_MACHINESOFTWARE360
Nicke
Answered By 15 points N/A #179243
In order to remove programs from your OS.
Follow the given steps:
1. Go to start menu.
2. Go to Control Panel.
3. Choose Add or Remove Programs.
4. A new window will be opened and there you can see all the programs that are already installed in your Operating System.
5. Pick the program you wish to remove in this case it is "360 safeguard" click remove, it will ask for permissions, allow them.
And
You are good to go!
Regards
Michelle Karla
Answered By 0 points N/A #179244
You can uninstall the 360 safeguard software. Read the below instructions step by step.
1. Go to Start button.
2. Click Control panel.
3. Find there Add or remove programs.
4. Then find in list the program 360 safeguard software.
5. Click the button remove it.
6. It will ask you to repair or uninstall.
7. Do uninstall it.
8. That’s a way you can install your any installed software from your PC.
Answered By 0 points N/A #179245
1. Go to "START BUTTON".
2. Then click control panel button.
3. Find Add or remove program button.
5. Click on remove button.
6. After doing that I will ask you to repair or uninstall it.
7. Click on uninstall button.
8. That's a way you can delete any installed software from your PC.
