How to remove the account from Google android tablets?
Posted on - 09/24/2011
I have one problem – I should return android tablet that I had the test, but cannot remove my Google account. First, I get a message that some services use information from your account. I uninstalled all applications and tried again, the answer is the same.
Then I tried reset the device, but unsuccessfully, the unit is turned off and stays off, when you turn it back on my Google account is still there. I tried to reset at least 5 times and the situation is the same.
Has anyone had this problem, and how it was solved? All I need is to remove my Google account from the unit, not to make it available to anyone else.
