How to remove ads from Safari browser?please help
Hi friends,
Please help me to solve this problem. I'm using Safari browser since 2 years now and it did not happened before. The problem I'm experiencing is too much ads on my Safari browser and I'm hating this that all the screen is getting covered just by ads. Why suddenly this change I don't know please help to remove this ads ASAP.
Best Answer by
Answered By points N/A #185230
Adware is a type of malware that involves scan ads to be shown on everywhere in your favorite browser. You might also be a victim of such threat.
In order to remove ads from your browser, you must have any good antivirus program installed on your system and scan your PC with it. You can use Norton, Avira, and Kaspersky etc.
If you’re on Windows, you can use Norton Power Eraser, an aggressive threat detector and remover.
Final try will be uninstalling Safari from your PC and then installing it completely fresh. Uninstall Safari from Windows or Mac. Download Safari and install it completely fresh.
Also, disable or remove extensions from your Safari which might be showing the ads.
Wish your better experience with Safari.
Answered By 0 points N/A #185231
One of the biggest problems with safari web browser users is that every time ads will pop up. But this issue has been solved with the arrival of Adlock extension. By adding this extension to your browser you will be able to get rid of ads. You can download this extension from the link.
