How to remove adware bug from my PC?help
Asked By 25 points N/A Posted on -
Hi guys,
I have windows 8 and while searching internet I'm able to see many adds that my desktop screen is filled with ads only including videos playing by it self. So I searched on web about it and came to know what is the problem it's a virus known as adware. But I don't know how to remove it so please help me how to remove this adware from my PC.
Best Answer by
Answered By points N/A #183754
Adware tries to tempt you to visit their scam sites so that they could send viruses and other malwares to your PC to achieve their goal. In order to remove them, you should have got any good antivirus installed.
There are many software that will do the task perfectly. I recommend Kaspersky, Norton, and AVG etc. They are perfect for you to solve your issue.
You can also use their “Internet Security” solution which will make your internet browsing more secured.
Answered By 0 points N/A #183755
Ad-ware can affect your system by slowing down its speed by downloading advertisement and also it has a great impact on your web browser efficiency. If you want to get rid of adware go to control panel and click on uninstall program. Here remove all the unwanted programs from the list. In order to avoid from further adware attacks you should download anti spyware which keeps your PC protected from all AD-WARE.
Answered By 590495 points N/A #304473
What you have on your computer is called adware. Basically, adware is any application that displays advertising banners while a program is running. The ads are delivered via pop-up windows that appear on the application’s user interface. It is often created for computers but may also be found on mobile devices. To avoid adware infection, users should be very careful on the types of applications they download.
Since your computer is now showing plenty of ad banners, download the Sophos Virus Removal Tool. It uses cutting edge technology found on enterprise-grade software which allows the detection of all types of malicious software. This is the best tool to use on computers that are already infected. Once the tool is installed, it will automatically download and update its virus signature database.
Once the update is complete, click “Start scanning” to scan your entire computer. It will scan everything it finds on your computer. When a virus is found, remove it then repeat the scan until it no longer detects a virus.
