How To Remove Adware From Mac Chrome Using Some Easy Setps
Hi. I have recently started using Mac Chrome. I want to remove the adware virus from my laptop. How to remove adware from Mac Chrome? Please reply ASAP. Thanks in advance.
Hi. To learn how to remove adware from Mac Chrome, first, open Google Chrome from the start menu. Then, click on extensions from the tools option which will open a Window where all the extensions which have been installed will appear. Then, select the adware and click on the trash option so as to delete the extension. Next, click on settings and set pages by opening a set of pages. The unwanted program can be removed by clicking on the cross button. A new page can be added as well in case there is only one startup page.
Select the appearance section and then check the option of showing the home button. Then, click on change. Next, use the new tab page so that the new option will be disabled. The current settings can be saved by clicking on OK. To restore the search engine, click on search and then manage the search engines by selecting the option. The unwanted search engines can be removed by clicking on the cross button.
Hope we helped.
