Hi everyone,
My PC is infected with adware and I want to remove it the earliest possible. So to remove this adware I tried uninstalling the adware named "SUP TAB" from my PC but still my PC is infected and it is running a lot of ads on Google Chrome what shall I do now. Is there any other solution to help me please let me know.
points
How to remove adware from my PC completely?please help
Adware are such bad types of malware that doesn’t only affect your PC but makes browsing completely a hell. In order to remove adware, you should have installed any good adware remover.
Lavasoft’s Ad-Aware is a good solve to your problem. It’s a good enough to solve your issue. This will remove all adware from your system.
Also, Norton Power Eraser is another powerful tool to remove adware and malware from your PC which uses heavy aggressive mode to erase threats. Download Norton Power Eraser.
If the problem is with Google Chrome only, uninstall the browser by removing all data. Then, download and install the latest Google Chrome. Download Google Chrome.
When your computer is completely infected by an adware, an ad will pop-up from time to time wherever your mouse points to and it doesn’t only happen when the computer is online. Even when the computer is not connected to the internet, different ads will still pop-up wherever the mouse is at.
Try downloading Sophos Virus Removal Tool. It supports Windows XP Service Pack 2 or higher, Windows Vista, Windows 7, Windows 8, and Windows 8.1. If you already have an antivirus on your computer, it won’t be a problem. The Sophos Virus Removal Tool works alongside your current antivirus program. It is used to help your antivirus protect your system but not as a replacement.
Once downloaded, navigate to the download folder and double-click the program. When it is installed, click on the “Start scanning” button to begin scanning your computer. See if this helps cleaning the adware that infected your computer.
