b.ernie96
10 points
Posted on - 08/23/2011
Yesterday I purchased a Screen Protector for my IPhone 3gs but when I applied it to the screen, there were tiny air bubbles on it.
I Removed the Screen Protector Twice & Applied it again carefully, to see if it works this way but no use. Bubbles were not removed. I've also tried to gently rub the screen, but its useless.
All this exercise, made my screen protector quite dirty.
Please tell me How Can I Remove these Air Bubbles?
Harry77
How to Remove Air Bubbles from IPhone Screen Protector?
Dear,
This is not a technical issue but thanks for sharing your problem with us. I am thinking of solutions to give you. Because I faced this problem several times with my iPhones and NOKIA phone. That time I found that there is no way to solve this issue, if it cannot be setup properly the first time.
If first time you put it gently, then also will find some bubbles. You need to rub carefully to remove them. This is the only way to set a protector. My suggestion is to please get it set from the iPhones center. They can do it perfectly as they do it every day.
I agree with Harry77, there is no solution for this. But you can buy another and let some experts to do it for you. They no how to put it perfectly. I have also experienced this it is not easy set it up it will create air bubbles.
It is very true that we need experts to do it for us.
Racquel
