How to remove aol idle?
Hello experts,
How to remove AOL idle? I just want to ask more things about this issue. For I want to remove an idle status but I don’t know how is there anyone of you here know about this kind of setup or on how to setup? I know you can help me guys. Just give me a proper instruction and I will do the rest.
Thank you.
Best Answer by Sharon bidron
Answered By 0 points N/A #188252
If you continue your chatting on AOL it will not show you idle. Idle is shown based on your setting. You can made you available rather than idle by simply clicking on preference then from the option set a long time in Set me as idle after xx minutes of not talking.
Answered By 0 points N/A #188253
First check if AOL toolbar is installed to your computer. If installed, you may uninstall it by following this directions:
1.    Select control panel
2.    Look for Add/remove program
3.    Select aol toolbar
4.    Press remove program
