How to remove aol update manager?
Hello fellows,
How to remove aol update manager? I am using windows 7 starter operating system in my acer computer desktop. Tell me the process of uninstalling or removing the aol update manager. Those updates will automatically pops up in the screen and it annoys me every time.
Christine Turner.
Best Answer by Heather marie
Answered By 0 points N/A #165437
The process of uninstalling or removing the aol update manager. On your desktop click My Computer. On the menu tab click Uninstall or change program. Find aol update manager and double click. Uninstall Wizard Window will appear. Follow the command buttons to complete the uninstallation. To uninstall it through Control Panel. Go to Control Panel. Select Programs. Check for Programs and Features and click Uninstall a program. Find aol update manager and double click. Uninstall Wizard Window will appear. Follow the command buttons to complete the uninstallation.
Best regards,
Heather marie
Answered By 0 points N/A #165439
Christine,
You can remove aol update manager by following the steps given below
1. Start Button
2. Control Panel
3. Programs and Features
4. Search for 'AOL Update manager"
5. Right click on it
6. Uninstall/Change
7. Do you really want to remove AOL update manager? Click yes
8. The AOL update manager will be uninstalled.
Once the process is completed, you may or may not restart your computer. That depends on you.
