How to remove application lock from my smartphone?
Hey guys,
I wanted to install application lock app in my smartphone and searched on web though I also came to know that once application lock app is installed its really hard to remove that app fro smartphone. But still I did install that app and now I want to remove it which have to be deleted from registry files. So please guide me step by step how to remove this app from my phone.
Answered By 0 points N/A #186278
Hi Dale, in order for you to delete the uninstalled application, you need to go to your backup registry to completely remove the uninstalled application. But in order to gain access most smartphones by default have restricted security. Also you need a Registry software Editor and one of the best so far is Resco Registry Editor. You just need to enter the My Registry from the main menu of the Editor, then go to HKEY_LOCAL_MACHINE\SOFTWARE\Android4.2\CurrentVersion\Uninstall. Then try to scroll down and check the value called “Display name” this will be the name of the file which you uninstall incompletely so its key is still in the registry.
