AltoDave
Posted on - 09/24/2011
Hello, I have a problem with some kind of virus. Eset NOD32 found it.Help please … One man told me that this is a rootkit, new .. And I do not know how to remove it…anyone have some idea? Thank You
ESET NOD32 Antivirus 4
Threat found
Alert
Object:
F:The Sicilian.exe
Threat:
Win32/Autoit.FL worm
Comment:
Event occurred on a new file created by the application C:WinIsass.exe
How to remove autoit.fl worm
You can delete virus files in two ways: manually, or with an anti-spyware program, in your case it will be NOD32. To remove harmful files manually you must be familiar with the exact file you have to delete because there’s a risk that the smallest mistake may destroy your Operating System, so choosing to use NOD32 is by far the safest and quickest way you can delete harmful files. Scan your computer with NOD32 it will displays the suspected files, and allows you to decide what should be removed.
mrs70
It's a kind of virus which attacks .exe files.For remove this virus you can use "W32/AutoIt Trojan Cleaner 7.0"-it's a free virus removal tool and it's only 436 KB.you can download this from this url- Download Link1
After download open the virus removal tool(you don't need to install it).Now click on the scan button.It will scan your whole drives for threats.If it finds any virus than remove it.After doing this your problem may solve.
