How To Remove AVG From Computer Using Some Simple Steps
Hi. I have been trying to remove AVG from my PC from a few days. How to remove AVG from computer? Please reply ASAP. Thanks in advance.
Hi. To learn how to remove AVG from computer, first, click on start and then select the control panel. Next, go to programs and then programs and features. From the programs which appear, click on AVG. Uninstall the already installed older versions of the software if any.
Then, uninstall the application. For the uninstall to take place, follow the steps appearing on the screen. The computer should be started again. Alternatively, download the AVG remover tool and double-click on the file to run it. Agree to its terms and conditions by clicking on continue. A list of all the products will appear from which the product which needs to be removed should be selected. Start the computer again.
Hope we helped.
If you have an AVG antivirus installed on your computer and you want to remove it, the easiest way is to run the built-in uninstaller. Click “Start,” “All Programs,” “AVG,” and then select “Uninstall.” If you don’t see “Uninstall” in there, second option is using the Control Panel. Click “Start,” “Control Panel,” and then “Add or Remove Programs.”
On the next screen, look for the AVG antivirus on the list and select it and then click “Uninstall” or “Remove.” Follow the succeeding instructions. Another way is to use third-party application. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your AVG antivirus among the programs and click “Uninstall.” Follow the normal uninstall process.
When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This will remove everything the program created on your computer. When it is finished, exit Revo Uninstaller then restart the computer. After booting, download the free version of CCleaner and install it.
Once installed, start CCleaner and clean your system. When it is finished, close CCleaner and that’s it. Everything AVG put on your computer has now been removed. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
