How to Remove dameware client script
I download Dameware client in window 7 but has some problem i want to uninstall/Remove Dameware client. Please tell me how i remove this what steps i have to follow if any one knows please help me.
Hi Harvey Logan i try to find some solution that may help you solve your problem.
You can uninstall dameware by:
Stop it by using command.
1. Press start and type cmd on the search programs and files:
2. Uninstall it on your computer using Add/Remove at the control panel:
You can also remove it using the command prompt.
Stop it first using the command stated above.
1. Press start and type cmd:
Hope this helps you.
