Hi guys I want to remove default social networks sharing buttons from my site but don’t know how to do it.As I already created social networks sharing buttons colourful but want to remove the old one’s which automatically displays below every post on my website.Please let me know how to do it
My platform is blogger
How to remove default social network sharing buttons from my blog?
To remove the old social network sharing buttons from the blog, go to the Layout Tab after logging in to your Blogger Dashboard. There, under the module Blog Posts, you will see a link that says Edit. By clicking on it, you will see multiple options, out of which one would be Show Share Buttons. Deselect it and sharing buttons will be removed from your blog.
Go to blogger sign in and select overview then you will see layout option on the left side of the page click on layout then you will see your blog layout in which you will see edit under your blog posts.Click on edit it will list some options like quick edit,email to friend, likewise it will show the option to select or deselect share on social networks uncheck the box.Your work is done
