How to remove drive mapping cache?
I am running a Windows 2008 server and somehow I managed to map drives using group policy. My question is, how can I possibly remove drive mapping cache?
You can do that by following these simple instructions.
1. Remove first the map drive in your computer, to remove right click on the map drive and select disconnect.
2. Click Start and Go to Control Panel.
3. On the Control Panel Click Network and Internet.
4. On Network and Internet, Click Delete browsing history and cookies.
5. On the General Tab, under Browsing History Click Delete.
6. Check all the boxes and Click Delete.
7. Apply all changes that you have done on the internet options.
