How to remove the endpoint media encryption
I'm having this trouble in removing the endpoint media encryption?
How can I remove endpoint media encryption as soon as possible to get my files back?
Thanks for the help.
If you wish to get rid of the security from the data files you have encrypted on your computer, you can do so by simply changing the qualities of those data files using windows explorer.
The first step is to open windows explorer and choose the file you want to remove security, simply right click choose a file and click qualities link from the context menu to launch qualities windows.
From the windows qualities choose an Innovative tab to open advanced attribute windows, click next, choose (encryption content) to secure your data and click OK to exit.
