amith kumar
240 points
Posted on - 06/21/2011
My sister has modified the default settings of default browser. I could get back to the original one including default home page. But I am getting trouble in hiding specific toolbars that have been installed. I am unable to hide toolbar named Brothersoft as there are no options like view in Chrome. Kindly provide guidance on how to get the original scenario without un-installation of Chrome or removing cookies and default settings.
Thank you.
Soleil
How to remove extra toolbars on Google chrome?
I have the simplest solution for your question:You have to note that those toolbars are not viewable ones, but are additional installations made with the Chrome software. They are additional softwares. It's very easy to remove these toolbars. Simply:
Go to control panel through start -> settings in xp.
Open add or remove programs.
In the list that pops-out select the required toolbar that you want to remove. Examples are asking toolbar, Brothersoft toolbar etc.
Just click the remove option,and you can uninstall it. Now open your Chrome browser, you won't find the toolbar.
Thus you have removed the toolbar.
Hi Amith,
You can just enable/disable installed toolbar in Google Chrome with just simple steps:
Open your Google Chrome
Click settings button the " WRENCH ICON" located top right below the close button.
Go to TOOLS, and click the submenu EXTENSIONS
Click DISABLE to disable the toolbar or UNINSTALL if you want to uninstall completely the toolbar.
Just restart Chrome afterwards.
