How to Remove the Fake Version of Angry Birds Space Edition?
What will I do if I accidentally install the fake version of Angry Birds and run it for about 3 days now?
Hello John Pike,
You mentioned that you installed a fake version of Angry Birds and it’s been on the system for 3 days now, and you wanted it removed from your computer. I could give you instruction in uninstalling the program. First, click start or the windows icon button at the lower left part of your computer. Then select control panel, it would open a window that says Adjust your computer settings. Select the option that says uninstall a program or programs and features. All the programs in your computer would show up including the angry birds that you have installed. Just click the icon of the program or highlight your choice and select uninstall. It would prompt you once it is done. You need to restart the computer for the changes to apply.
Atanasosk Pelayo
