How to remove Firefox from PC without deleting personal data
I am using Windows Vista and would like to remove FireFox from my PC. I tried to uninstall it by going in the Add/Remove programs section, the pop up box appeared saying the program was being uninstalled but it did not. Please tell me how to uninstall FireFox from my PC? I dont want to remove any personal data and customizations, so pleased tell me such a way that this data remains intact. Thanks
Best Answer by
Answered By 0 points N/A #159581
The firefox is uninstalled now. Hope you have opted for keeping the data safe while uninstalling Firefox. Now you have to follow a few steps to clean the traces.
  1. Go to My Computer -> C:Program Files, look for a folder named 'Firefox'
  2. Delete the entire folder(If you use any other product of Mozilla, then delete the contents of Mozilla Firefox only.)
  3. If you have any registry cleaner software, use it to clean the dead entries from the registry post-uninstallation.
Answered By points N/A #159582
Uninstalling Firefox without deleting browsing data and other information is very easy.
1. Go to Control Panel >> Programs and Features >> Uninstall a program.
2. From the list, find out Mozilla Firefox.
3. Select and right-click on it and then, select “Uninstall”.
4. Uninstall it normally. If any option comes forward saying whether you want to delete your browsing data or not, say “No”.
Done.
Now, install Firefox once again and you will still have the personal data on your PC.
If you want to remove Firefox completely with registries, use Wise Program Uninstaller. This is a program that has two options: “Safe Uninstallation” and “Force Uninstall”.
Just find out Firefox, select it and press “Safe Uninstallation”. After the program is uninstalled, it will scan your PC for leftover registries and files. Then, simply click “Remove”.
Firefox is completely hoed from your PC.
Answered By 0 points N/A #159583
Hello Adolfojeremiah,
Have many ways you can uninstall Firefox from your PC keeping your data intact. As well these solutions you can apply more techniques too. Go this Techyv page for more information.
How can we uninstall Firefox using command prompt?
