Hello I'm Irvin,
I just want to know how to remove the genuine notification in windows xp sp2 and 3.
My background became plain black, and my audio is not working.
I want to remove the genuine notification, is there a software to remove it?
can you give the link? or can I remove it manually?
Thank you so much!
How to remove genuine notification in Windows XP?
The main thing is there is no way to remove the genuine notification manually. But, You can do one thing.
Just gather some information like when it started coming from. The you can just restore your computer back to that point. This is not a complex thing but it will take around 20-30 minutes to restore back on the system files that exist in your system.
Just click F1 you will be seeing a Help and Support of windows. Then search for the column like system restore. Just click on that and choose the date before your genuine has come and click on restore. It will reboot your system and restores to earlier stage. You won't loose any data other that installed files.
Dear Irvin,
Here is the permanent solution of your problem. But sorry to say that you need to install the fresh copy of a new windows XP and then it will works.
1. At first get rid of your old installed windows
2. Install the fresh copy of new windows. Remember to format the drive where you going to install windows fresh copy
3. After finishing the setup, go and download the windows XP loader from the following downloading link. You can also get this from windows installation CD disk
4. Run that program
5. Restart the windows as it says
Thanks for your time.
