How To Remove Google Web History:
Hi. I am using Google Chrome as my default browser. I want to clear my browsing history. How to remove Google web history? Please reply ASAP. Thanks in advance.
Hi. To learn how to remove Google web history, select the icon (â‹®) and then delete options need to be selected from the menu which appears. A menu called delete web and app activity for will appear from which the advanced menu needs to be selected and then all time needs to be selected from the list. Then, click on delete. No more items will appear in the Google web and app activity after the process gets completed. To delete the entire history, click on the icon (â‹®) and click on settings. Next, slide the switch for your searches and browsing history to the left thereby disabling it.
Next, pause the browsing activity and this will turn the button gray. To pause all the activities, slide the button for each activity to the left. Specific items can be deleted by clicking on the menu; history and then clicking the cross button for each item in case it is to be removed.
Hope we helped.
Notifications
