How to remove hdd password external?
Hello Experts,
How to remove HDD password external? There is a password for my external hard drive and I want to remove it to make it accessible for me because I don’t want to get in to the point that I might forget the password it would be a big problem if ever.
Thank you.
Best Answer by Goram Ian
Answered By 5 points N/A #180502
At first connect your external HDD and unlock it. Now go to the Properties or Tab setting option. Enter into the Security option and change the require password option. If there is any password asking software in your HDD provided by the manufacturer, delete it/ uninstall it from your system.
Answered By 0 points N/A #180503
Some computer even offers the luxury of a “Clear User Password” option. If you have the option, simply press this and then press “Enter” to delete the password. On the other hand you should take help from your pc service center.
Answered By 60 points N/A #180504
Hi Danield Mike,
Ok here's some simple tips on having HDD password external:
  1. You must not make a password with critical/uncommon characters.(like codes, scrambled letters, etc.)
  2. You must input a  familiar words.(like name of a person(favorite actress,niece,your name or relatives))
Here's a like below in which may help you in removing your password:
If you want to share some ideas and experience with other user, you can go to the link below:
