psytrip
Posted on - 10/17/2012
I am wondering if some one install a keylogger software on the system (which is nearly undetectable). How to completely get rid of this kind of software or Keylogger Engine? Any help would be appreciated?
Thanks,
Vivek
How to remove a keylogger engine installed on your system?
Keyloggers often works just like a computer viruses so you can remove it by using an effective antivirus software such as Symantec Norton Antivirus, Kaspersky, McAfee VirusScan, eTrust EZ Antivirus, Panda Titanium or AVG. And you can also remove it by using some advanced spyware removers that is capable of scanning your whole system and remove keyloggers and all its components.
You can use Spyware Doctor, Ad-Aware, Spybot Search and Destroy and a lot more. But in cases that these antivirus or anti spyware failed to remove the keylogger, you can go to https://www.2-spyware.com/. They provided instructions on how to remove malware and will allow the users to manually delete it.
Key loggers are programs that run in the background of a computer and its function is to record input from a mouse and keyboard. Some are even advanced enough to log all computer activity and take screen shots. Here is the link where you will fine how key logger software can be removed:
