Hi techyv,
How to remove links in pdf file? I got so many pdf files that contains different links but I was instructed to remove all the links because it was a mistake and have to be edited. 32 pdf files with links to be removed and I need to get this done as soon as possible. Can you help me out?
Hoping for your help and kind consideration.
How to remove links in PDF file?
Hi Kristen,
It depends on the type of software you are using. Different software has different ways to delete hyperlinks on PDF files. The problem about PDF files, whenever you move your cursor to a URL or an email address, it will be read as links even though these are plain text.
If you are using Acrobat Standard or Pro, you can click on Tools menu and choose the Advanced Editing and Link Tool. By doing so, it will make links visible in rectangle forms or you can try the Advanced menu then Document Processing and choose the Remove All Links option.
Hello Kristen James,
The following process is very simple and will help you do delete those links
• Click on the link tool or the selection key
• Click the rectangular you want to erase
• Press the delete key or choose edit then delete.
