How to remove lock format USB using windows 7?
I have windows 7 installed and want to format an UAB but can’t do so because of lock format USB.
How can remove protection?
Any kind of help would be appreciated.
Hey Wyman Zab
1. There are some USB flash drives that have a lock on it. If that's so then unlock the switch
2. Check if any folder in the drive is write protected. Right-click on that folder and Select properties and then uncheck the Read-only option.
3. Try this link out. It will repair your USB drive:
I hope it works
Hello Wyman,
The following is a method that will help you remove write protection from your USB flash drive or memory card:
Carl
Notifications
